I've recently purchased some Halo Projector headlights for my MX3. Theres just one problem, I'm a complete fool at this wiring set up so I was hoping to get some help. I looked at some other threads and although they seemed to be well done I need some specific advice on these.
These are them here.
Now I think I understand how this blue plug works here, I plug it into where the other plug that had a bulb plugged into. i believe the red cable goes to the battery, and there is a relay so my battery isn't drained. Also there is a fuse within the little black rectangle.
I plugged the old bulb connector into the blue plug thing, my low beam and high beam was set properly.
I put some fogger covers I have on them also to see how it would look.
Now the real problem comes here
These two cable setups have me completely baffled.
This one here:
Is where the vertical signal lights are attached to, my limited understanding makes me think that the red wire must be attached to the signal wiring and that the black is a ground cable?
Then theres this:
I believe these are for the actual halo lights that light up. I think the black is again a ground wire while the white works to do the actual halo lighting. I don't want to have the halo rings lit up constantly but I think I'd link to wire those to a switch, then put the switch in my dash somewhere.
Anyway, can you guys help me out with some specific wiring help?
Much appreciated,
Rob
