Found a KLG4, I need info
mikeetown
Post by mikeetown »
At my local scrap yard, I found a 1999 mazda 626. I dont know how many KM are on it but, It might be a motor that overheated a few too many times. On the side, it says "drive in......Hot". I dont know what it means and they dont either haha.
My questions,
-On my mx-3 i just got that has a K8 in it, can I use the KLG4 intake manifold on the K8-DE and will it increase the power and so on??
-If I take the MAF off it, can I wire it to my K8 and will it work (my mx-3 is OBD I). I know that MAF's are better.
-What else is worth salvaging??
mikeetown
93 Black GS - J-spec KLDE, CLEAN CAR
92 Red GS - J-spec K8ZE, stripped interior - Written off
2004 Infinity G35 Track Edition - 6 speed manual
viewtopic.php?f=17&t=79142
Re: Found a KLG4, I need info
mikeetown wrote:My questions,
1) DE's gain a few HP from putting on a ZE intake, but last person I know who tried a DE intake on a K8 he said it didn't run right
2) MAF's are better, yes, but your ECU had to be designed to use it. Your ECU is setup for a VAF, and it probably won't work if you put anything else in there. Even look at people swapping between the JE50 and KL01 VAFs cause a difference on how a motor runs just based on the values they send back to the ECU. Your ECU probably doesn't know what at all to do with a MAF
AaronTietje
Post by AaronTietje »
I have a g4 on my car but have not been able to do a real test on it yet. (mine is a klde with a g4) A plus to the G4 is that it-in conjunction with the front valve cover-eliminate vacuum lines. I would keep the Je50 as long as you are using the k8 ecu. I speculate the TB would probably give you some additional power. :shrug:
Sleeper6
Post by Sleeper6 »
A maf sensor can be used but its a pretty intense swap, if your up to it heres a guide:
http://forums.probetalk.com/showthread. ... conversion
Also Im not sure if it can be done on an obd1 car.
Sleeper6 wrote:A maf sensor can be used but its a pretty intense swap, if your up to it heres a guide:
Ohhhh! Well that's new, well not really, looks like it's been over a year now. Well that's not just a MAF conversion to the stock ECU, that's changing the whole engine management system to a Millenia ODBII system that uses a MAF. My statement about the MAF not working with the Mx-3 ECU still stands.
1. this is obd2 only. the obd1 millenia did not come with a maf
mikeetown wrote:my mx-3 is OBD I
Well that solves that one, lol!
MrMazda92
Post by MrMazda92 »
Well to be fair it will work, it's just more work than most would do. I personally wouldn't do it, but the entire G4 may be worthwhile. Define "may have overheated a few times" though... before you buy it.
mikeetown
Post by mikeetown »
its 130$.
Ya, I am definately going to ask people there if they know what the writing means. If it has under 150,000km and isn't an overheated engine I'm going to buy it.
mikeetown
mikeetown
Post by mikeetown »
crap haha. I need the wiring harness and OBD ECU because of the MAF unless i can run my VAF with this engine.
mikeetown
mikeetown
Post by mikeetown »
2) MAF's are better, yes, but your ECU had to be designed to use it. Your ECU is setup for a VAF, and it probably won't work if you put anything else in there. Even look at people swapping between the JE50 and KL01 VAFs cause a difference on how a motor runs just based on the values they send back to the ECU. Your ECU probably doesn't know what at all to do with a MAF[/quote]
Thanks for the good information
mikeetown
Keep your VAF and ECU, port match your DE to the KLG4.
Here's some useless info I found time consuming. http://www.mazda626.net/topic/37114-kld ... ge__st__45
davmac
Post by davmac »
You can definitely use the KLG4 intake without porting K8 or DE heads. The KLG4 intake has oval opening where it attaches to the cylinder heads. I have KLG4 intake on a KLDE with bored out DE throttle body, DE VAF and DE ECU. My car runs great with smooth idle and good power. I can't confirm increased power over the straight DE intake and TB, but I didn't lose any power and enjoyed making the modification.
