Swap woes, need help with injector issue
Sleeper6
Post by Sleeper6 »
I could use a little help or atleast a point in the right direction if anyone can shed some light for me. Today I swapped out the injectors on my DE from the Milli S ones to stock ones mounted in rails from the JY to stop my cylinders from getting washed out. After putting them in the car would run but only if I held the petal in so as simple elimination I swapped the regulator from the modded S rail over that I knew to be good onto the DE rail (not sure if this was a good idea or not) and the car would hold idle again and considerably lower from the 1800 it had been back to 1200rpm. Now however if I go to accelerate it tries to cut out and if it isnt floored quick enough it will otherwise it recovers until the next time you accelerate. My question is could the regulator from the S rails be defunct for stock injectors now or should I swap in my old regulator from my K8 rails (again not sure if that matters or not). Otherwise the engine is running smooth and it doesnt sound like theyre not pulsing but I could be wrong.
Any help is appreciated
The engine was previously turbo'ld if your wondering why it had the S injectors
Ryan
Re: Swap woes, need help with injector issue
Post by Ryan »
Stock injectors, stock FPR, stock tune?
Sleeper6
Post by Sleeper6 »
Yea all stock only difference is K8 VAF. Did get some info I didnt think about on PT and I reset the ecu but Im going to wait for daylight before driving just incase I have to break out the tool box. I didnt even think to relearn it to the new injectors but will see tomorrow.
mikeinaus
Post by mikeinaus »
are you running a k8 vaf with a klde ecu? unless your ecu is chipped i was under the impression you needed a de maf with de ecu.
Sleeper6
Post by Sleeper6 »
So far so good, swapped in the KL vaf that wouldnt run it before and now has it running again. Dumping the initial oil out this weekend for castrol and looking forward to the best!
