Need some help ASAP for some wiring issues
Posted: September 29th, 2011, 10:47 pm
First off yesterday i started pulling out all the old alarm crap that was dying (the alarm itself was old and just wasnt installed properly).
I started pulling and snipping and forgot this part was for the MSD setup that my brother made for the 6AL box and Disty wiring. Well i hastily started removing not realizing that this for the Disty and not part of the alarm. Can any of you wiring experts tell me which wires go back where so i can re solder them back in place?
He was not using a HEI Module for the Blaster Coil, instead was using the MSD box, the Blaster coil, and the Modified PRD Disty Cap.
The Box he made:
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111356a.jpg)
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111356.jpg)
The wires i removed from the box wiring:
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111357.jpg)
For Informations Sake, below is a list of the MX-3 Distributor plug wire colors & their functionality:
6-pin Plug (from the top to bottom)
Solid Orange (Ignition control module ecu trigger)
Black w/green stripe
Pink w/white stripe (camshaft position sensor SGC signal)
Pink w/green stripe (camshaft position sensor SGT signal)
White w/red stripe
Black w/light-green stripe (ECU constant ground)
3-ping Plug (fromp top to bottom):
Solid Blue (ignition coil +)
Yellow w/blue stripe (tachometer signal from ignition coil)
Solid Red (ignition coil -)
More Information on whats wired:
Black with Green Stripe on Left, Orange in Middle, Yellow with blue stripe on Right
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111535.jpg)
White Wire is from MSD Box and Disty Red wire (Ignition Coil -)
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111533.jpg)
Red Wire is from MSD Box and Solid Blue (ignition coil +)
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111531.jpg)
Box Wire Information:
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111356a-1.jpg)
2nd Need of help:
The Alarm was also wired poorly to the door locks and after i removed the wiring for the alarm, i need to know where to splice the wires into.
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111355.jpg)
3rd thing:
Battery relocation. When it was done, dont ask me why, but the red cable is the neg, and the black is the power. The black cable is routed to the front of engine, the red is grounded to the seat bracket. Is this sufficient grounding?
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111403.jpg)
4th thing:
Since doing the MSD Box and coil - Does the 3 wire plug need to be on the disty still or can it live off of the disty in the trash can? Also in the 2nd pic - the tiny little wire connecting to the disty, does it need to be plugged in or left off since im running the box?
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0929111359a.jpg)
![Image](http://i2.photobucket.com/albums/y46/coltongrundy/MX3/0924110857.jpg)
The Box he made:
White w/red stripe
2nd Need of help:
3rd thing:
4th thing:
