About 2 weeks ago, some water got in my alternator and it caused it to stall and not start. After drying out everything was fine, started right up, no charge needed or anything like that. A few days later, my check engine light came on while going up a hill, i pushed the clutch to shift and it went out. A couple days later I was driving on the highway and it came on, i shifted and it went out. Same thing happened the next day. I dont know if this was a coincidence or not?? This morning it went on and off 5 times on an 8 mile trip. It stayed on for about 5 seconds each time. My car seems to be running fine until I come to a stop and it bogs alot more than it did (suprised it stays running). I already read something about the light going on and off being a soft code?? Or something along those lines. I pulled the codes and got code 16, something with the EGR valve?
Any help is appreciated as I would like to try and get to this problem before it is too late. Thanks
CEL turns on and off whenever it feels like it
Re: CEL turns on and off whenever it feels like it
http://www.mx-3.com/manuals/showimg.php ... F2-085.gif
Troubleshooting procedure for code 16. All you need is a multi-meter and some long leads.
hopefully this will be the last time im posting about this problem. the diaphram in the egr valve moved as if it was supposed to. I started the car up and lifted the diaphram and the car almost died and when i let it back down it was fine. Also, the small hose that connects to the front of the stock airbox, i have an aftermarket so mine just hands there, had something jammed in the front of it. I removed this and since then its been fine. No check engine light and no rough running anymore. I dont know what it was.
That hose is the vent hose that opens the EGR. If it was plugged that was the problem.
