Hey kids...
I have started to prepare to do my front brake upgrade and found today that one of the hubs I acquired from another member is toast. So I need another one. Just the hub...not the spindle or the bearing.
I am also removing the ABS system so I need to swap to a conventional proportioning valve. If anyone has one that isn't rusted up I'll take it.
Feedbcak thread is in the sig. I'm pretty easy to deal with.
Thanks.
Charlie
[WTB] One front hub and a GS brake proportioning valve
Sleeper6
Re: [WTB] One front hub and a GS brake proportioning valve
Hey Im not sure if I can help out with a valve but I can still get you that hub new at cost + shipping if yould like
CAn you tell me what cost+ shipping to T6M 0A4 is?
Actually quote me for 2. Might as well.
Thanks.
Thanks.
rockauto has brand new hubs for 39.99. If you need help shipping it to canada I can assist
I did get a hub but thanks.
K you need to send me an email address so I can give you money.
I will be swapping out my hubs for new bigger ones this weekend. There is nothing wrong with my stock ones, but you can have them both for free if you want them
klze swap, wisco 8.5 comp pistons, pauter rods, act stage 3 clutch, lightened flywheel, UR racing pulley, flex-o-lite oil cooler, 2.5" custom exhaust with high flow cat, B&M short throw shifter, S&R cross drilled rotors, , B&G lowering springs, maxxim 17" gun metal rims, modded nissan injectors, walbro 255 lph fuel pump, areomotive afpr, msd 6a , magasquirt v3, and turboed
The hub problem is solved and installed. The proportioning valve might turn into an aftermarket solution. I haven't decided how i'm going to attack that yet.
