replacing front brake rotors
Posted: March 25th, 2011, 3:59 pm
by scotty12_08
having trouble gettin the axial bolt off to take the rotors off. do you guys have and suggestions for gettin the rotors off??
Re: replacing front brake rotors
Posted: March 25th, 2011, 4:09 pm
by xSocialx
Electric or air impact gun.
Posted: March 25th, 2011, 4:17 pm
by Ryan
5' cheater bar and a 3/4" breaker bar.
run the car when your helper hits the brakes, power assist.
Posted: March 25th, 2011, 4:39 pm
by kakarot135
Why are you taking the axle nut of to take the rotors off you should be able to pull them without taking the axle nut off. Once the caliper is off you should be able to pull them off. If they are stuck there is a threaded hole you can screw a bolt into to pop them free. Or a hammer with light taps around the hub will break the rust free.
Posted: March 25th, 2011, 4:58 pm
by scotty12_08
no need for the power assist. the thread hole worked fine
