replacing front brake rotors
scotty12_08
Post by scotty12_08 »
having trouble gettin the axial bolt off to take the rotors off. do you guys have and suggestions for gettin the rotors off??
xSocialx
Re: replacing front brake rotors
Post by xSocialx »
Electric or air impact gun.
Ryan
Post by Ryan »
5' cheater bar and a 3/4" breaker bar.
run the car when your helper hits the brakes, power assist.
kakarot135
Post by kakarot135 »
Why are you taking the axle nut of to take the rotors off you should be able to pull them without taking the axle nut off. Once the caliper is off you should be able to pull them off. If they are stuck there is a threaded hole you can screw a bolt into to pop them free. Or a hammer with light taps around the hub will break the rust free.
Kakarot 135
scotty12_08
no need for the power assist. the thread hole worked fine
