quick question
- mazda915
quick question
can the iac sensor allow the car not to turn on . i adjusted the screw one full turn in and i forgot the have it wired to grd and ten but once i turned the screw car was still running then i saw a vac line wasnt hooked up , looks it is in the solenoid under the throttle body , well the uninstalled line had no vac so i was assuming it was just pressure so i blew on .. was fine then sucked on it engine started to die then shut off . now wont start lol wtf . im i just over looking the basics so now i tryed making sure all sensors installed the intake and vaf are ok no so idk any ideas guys ? i am confused on something so little lol ![Shrug :shrug:](./images/smilies/shrug.gif)
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
- Ryan
Re: quick question
If you adjusted the screw without ten and gnd, it shouldn't have even affected the idle at all, the ECM would just compensate around what you did. Don't do that anymore, its not really good for the tune of the system.
You probably just missed a plug, there's no reason any of this would cause a no start. Check the VAF. TPS, IAC.
