gauge install
mx3matt
gauge install
Post by mx3matt »
so i have a wideband, volt, and water temp gauge to install and my question is will a 10 add a fuse hold enuff power to run these three gauges?
i'm gonna be installing these tonight in addition to a new cluster with speedhut indiglo overlay(wiring that to my dimmer switch) just wanted to make sure i'm not gonna be underpowering the gauges or overloading the add-a-fuse.
Newfie_dan
Re: gauge install
Post by Newfie_dan »
10 amp should suffice, if not then you can use the 10 amp add a fuse to turn the relay on/off with the key and wire the constant power to battery with a 15 or 20 amp inline fuse there.
mx3matt
Re: gauge install
Post by mx3matt »
the indiglo cluster i'm wiring into the dimmer for power so thats taken care of.
it was just the additional 3 gauges(depo racing wideband, and 2 cheapo gauges) that i was wondering about but the add a fuse should cover three gauges i'm told.
whitete
Re: gauge install
Post by whitete »
sounds good ! thinking of the same thing i already have the temp gauge, i was thinking about a 10 A or 15 A inline off the dimmer too
let me know how it goes
Thanks ,
Terry
Red96'Mx3 KL-ZE 2.5, CAI, full 2.5'' exhaust,cat delete, black stock rims polished lip, cross drilled brakes, (aftermarket bumper with halo foglights-Needs work) .
http://www.cardomain.com/id/whitete
Previous rides
Purple94' Mx3 K8-ZE CAI, Exhaust, plugs,wires
Purple95' Mx3 K8 american, CAI, Exhaust, plugs, wires,cap/rotor fuel pump, short shift,
Black 94' Mx3 i4 Stock ( hit by dear )
