What engine do i have
john1983
Post by john1983 »
ok so i recently purchased a 92 MX-3 from a private seller. When i bought the car they told me the prior owner had swapped the engine in it i am trying to figure out exactly wich engine i have the only thing i do know so far about the engine is that its a 6cyl 24v dohc but i have no idea if its the k8-de 1.8,k8-ze 1.8,kl-de 2.5 or the kl-ze 2.5 is there any thing on the engine that would tell me? please help
92 MX-3 6cyl dohc 24 valve K8 cold air filter custom exhaust drift body kit carbon fiber hood 17" focal rims Kenwood KDC-MP635 headunit Pioneer 6.5" componet door speakers and 4" rear speakers 500 watt boss amp powering 12" sony explod
My Work Logviewtopic.php?f=46&t=76603
Newfie_dan
Re: What engine do i have
Post by Newfie_dan »
take a pic of it and we will see if we can help you out, there are lots of posts on identifying a klze on here just search it, also a klde has a straight neck intake manifold whereas the k8de has a curved neck, a klze can have either straight or curved depending on which one you got. Externally they are all the same size.
john1983
Post by john1983 »
i will have to take a pic and post it within the next few days but in the mean time is their any suggestions as to how to identify wich engine i have
All the V6's are 24v DOHC
viewtopic.php?f=23&t=56280
K8 - stamped K8xxx. I don't know what the stamping for a K8ZE us
KLDE - KL-101, KL-1A1
KLZE - KL31-101, KL31-1A1
john1983
Post by john1983 »
this may be a dumb question but whats the possibility of some1 just swapping out the intake manifold, the ones in the image look like they are all the same bolt pattern
Ryan
Post by Ryan »
all the manifolds interchange, but that could mean they used the K8 manifold on a 2.5 too.
You need to check a few things. Head codes and block codes would tell you for sure.
Ryan wrote:all the manifolds interchange, but that could mean they used the K8 manifold on a 2.5 too.
Exactly. However, almost no one puts the 2.5 IM on the 1.8, but it's common for people to run the 1.8 IM on the 2.5, *usually* only a temporary setup because it restricts power.
john1983
Post by john1983 »
i hate to sound dumb but where can i find these codes would they be in an accessable place
solo_ryder
Post by solo_ryder »
Why don't you take some fricken pictures and post them up
Head codes are stamped on the heads. The easiest one to see is on the backside of the front head. Look there, just infront of the intake manifold and you will see the code stamped just below the valvecover.
Kl31- is a klze, kl- is a de and k8 is self explanatory.
john1983
Post by john1983 »
Ryan i plan on takin some pics but till i can post them i was wonderin if there was anything i could easily just look at my car is parked at my uncles house right now so when i go there to take the pics i was gonna see what i could find
john1983 wrote: i was wonderin if there was anything i could easily just look at my car is parked at my uncles house right now so when i go there to take the pics i was gonna see what i could find
solo_ryder wrote:Head codes are stamped on the heads. The easiest one to see is on the backside of the front head. Look there, just infront of the intake manifold and you will see the code stamped just below the valvecover.
RX8SE3P
Post by RX8SE3P »
Hopefully this link works, there's a head code, you can find it near the bottom of the intake manifold where it bolts to the heads.
http://carphotos.cardomain.com/ride_ima ... _large.jpg
1995 Eunos 30x KLZE
john1983
Post by john1983 »
thanks rx8se that should be helpful just wish i knew when i will be able to go over my uncles to check things out i hate not havin it right out front damn neighborhoods that like to call county for expired tags :x
Jeeeze buddy, borrow a camera or cell phone and take a pic of the engine then open a Photobucket account and use the IMG to post the pic here. This is your easiest solution.
Daninski wrote: open a Photobucket account
Don't even need to do that, use ImageShack for temporary stuff, quick and easy.
