Issue with 3rd gear!
- bbunkerc397
Have an issue with my 3rd gear sometimes it won't go into gear even at like 2500rpm and a grind now and again. The tranny has new syncromesh when I had it rebuild 2 years ago.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
- Newfie_dan
Re: Issue with 3rd gear!
try doubleclutching see if that helps, that will tell you if its the syncro at fault or the gears.
My slave cause that problem, was convinced that it was the gear issue since 3rd was common to wear it's syncro and eventually 5th stating doing it until my slave died and I replace it, along with a stainless clutch line, the problem went away!
- bbunkerc397
I also have a new slave, but original clutch line. Maybe that's my problem.
- cWs306
i got no 3rd gear when im down shifting from 4th or 5th. i gotta go to 2nd first befor 3rd will open up. weird eh? what would cause that lol.
my ears hurtcWs306 wrote:i got no 3rd gear...
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Sometimes my turd gear is a little sensitive as well. Might look at doing the slave over like NDfurSps says.
- MrMazda92
My *eyes* hurtDaninski wrote:Sometimes my turd gear is a little sensitive as well. Might look at doing the slave over like NDfurSps says.
So is there a fix or what? Kinda like tapping 'shave and a hair cut' and leaving out 'two bits'. You need to finish this or at least tell us you wimped it and gave up.
- bbunkerc397
Sorry guys, the new synchromesh kit in my transmission needs to be worn in a bit so it is progressively getting better on shifting into 3rd. The odd time it gives me trouble but with 12000kms on the rebuild it is a lot better shifting now.
cheers
cheers
I had trouble with a trans in a car once getting it into 1st in the morning after 110k. Bought it new from the dealer with all dealer fluids in it. I sold it and the guy who bought it put a lighter fluid in and never had a problem. Just thought I'd mention that.
