OK my mx3 died about 5 months ago and so I have been on the search for another one. I found one for $400 that needs a pressure plate and clutch. its the 1.8L v6... I already have the pressure plate and clutch for a 1.6L I4... can I put this clutch and pressure plate on the v6 engine? its rated for 270 HP and 234 ft/lb torque.... please be merciful, I know nothing about transmissions and such.....
Thanks!
Clutch and pressure plate interchangeability
did you know that my mx-3 thinks....?
- Evo_Spec
Re: Clutch and pressure plate interchangeability
you should find the answers somewhere in here
http://www.mx-3.com/phpBB3/viewtopic.php?f=30&t=65792" onclick="window.open(this.href);return false;
I couldn't find what I needed......
but based on the part numbers I got from napa the 4cyl clutch will NOT fit the V6....
