Clutch problem?
- wreckedgs
Clutch problem?
GF just bought a 4cyl 1.6 sohc the clutch is bad i believe but im asking for a second opinion, i can put the car in all the gears but i have to rev it up to get the car to roll forward or back....its pretty much like i am riding the clutch but im not...i can also take my foot completley off the clutch while the car is in gear and it acts just like im sitting in neutral, normally the car would die instantly when in gear and the clutch isnt pressed in but hers just idles like its in neutral...i need help with this asap...i cant let her drive my gs lol
Re: Clutch problem?
I suggested of the every one and my experienc said the when aclutch is worked are very smoothly a manual transmission is to like an extension of the right arm. so we have complete control over the gears. so we decide the when to shift is which gteare to use. so the no invervention by a computer and no islolation from the drive.
- wreckedgs
Re: Clutch problem?
wtfhelboy wrote:I suggested of the every one and my experienc said the when aclutch is worked are very smoothly a manual transmission is to like an extension of the right arm. so we have complete control over the gears. so we decide the when to shift is which gteare to use. so the no invervention by a computer and no islolation from the drive.
Re: Clutch problem?
I just hurt my head reading hellboy's post
anyways for wreckedgs, this definitely sounds like a clutch!
- wreckedgs
Re: Clutch problem?
thanks dark_rider and im definitely gonna change out the clutch this weekend then lol
