Adding power locks and windows to non-powered car
red17
Post by red17 »
im sure there is many pages for this topic, but i just wanted an updated post on it. i have manual locks and windows, and i hate it. anyone have any thoughts on the best kits to buy?
pox
Re: Adding power locks and windows to non-powered car
Post by pox »
Im in the process of swapping 92 gs power doors onto my 94 rs. Plug and play.
Took the bp+t out of the mx and swapped it into a 95 escort wagon. ;)
Ryan
Post by Ryan »
You only need a donor power door.
You need the inner door panel, the switch, and the window regulator. Everything else bolts over.
power locks is easy. Pretty much every car in the world has the same power lock set up.
Power window assembly is fairly easy to remove. I kept the ones from one of my donar cars just in case mine go.
red17 You need to post where your from.
