hei mod questions
SpatialTerror
hei mod questions
Post by SpatialTerror »
im done a little bit of searching around. and kinda figured out the how to of hooking it all up.
now im just wondering on where to get the parts. and what parts are best.
i have a klze mx3 with the k8 dist.
so could i get some links?
SpatialTerror
Re: hei mod questions
Post by wytbishop »
Use a MSD Blaster SS coil. It can be mounted in any orientation. The Blaster and Blaster 2 are oil filled and must be mounted upright.
wytbishop wrote:Use a MSD Blaster SS coil. It can be mounted in any orientation. The Blaster and Blaster 2 are oil filled and must be mounted upright.
Hitler lives! You musenze use anything but the SS coil or it's the Russian Front for you. :lol:
You can find MSD Blaster coils anywhere and NAPA has the 1982 Chevette modual as discussed here. http://www.mx-3.com/phpBB3/viewtopic.php?f=23&t=69006" onclick="window.open(this.href);return false;
SpatialTerror
thanks guys ill put up some pics when i get some money to do this projects
SpatialTerror
