Sometimes my 92 doesnt hold a steady idle and bounces between almost a stall and 1k rpm. It has never stalled from this. Engine doesnt show any code's. When i put on the A/C and the compresser is engaged it idle's beautifuly ( dont know why ) Someone suggested take off the IAC and clean it?
Also its not like this all the time, Will be good for a half hour than turns bad for a half hour
Whats the proper procedure to do that?
B6 Sohc, Jumpy idle
- Ryan
Re: B6 Sohc, Jumpy idle
Check the intake tubing for leaks and cracks....
resqrandy
My 93 did the same thing. The problem with mine was the vaccum lines were all junked up. I gave it the seafoam treatment and it purred like a kitten. It runs smooth at first and with the A/c on because it makes the car idle fast when its cold or is carry more load.
'99 F-150 Supercab Stock +Stereo System
'93 Mazda MX-3 1.8L BP05 5 Speed
Motor from '91 Mercury Tracer
ECU, Plug wires, fuel rail, Exhaust Manifold and Valve cover from '92 Protege
Wire harnes and VICS Solenoids from Escort GT
viewtopic.php?f=46&t=73674&p=548166#p548166
Photo Album:
http://www.facebook.com/album.php?aid=1 ... 711dabc18f
Photo Album:
