i just got new plugs and wires... and accidentally pulled out all the wires at the same time. i need to know which order the plugs go in. if someone can help with a diagram or anything.. that would be great,
92mazdamx3 1.6l b6me motor...
help?
Spark Plug Wiring Diagram?
- Mx3TD
1992 MX3, RS..Sanded... Short shifter,Seat Covers;) , Fart can that sounds decent (:
1992 MX3, GS. Lowered, 18in. chrome rims., Blacked out Tails, Weird Bodykit.
- umcamara
Re: Spark Plug Wiring Diagram?
That's what the shop manual is for...
Distributor Cap View
Firing as seen from front of car-at the bottom of the page
- Mx3TD
thanks man, helps alot.
- umcamara
No problem. Although I'm sorry, I just learned that the '95 shop manual is completely wrong for those specs. The links I provided are for the '92 shop manual. I'm not sure if it's right for your vehicle. If you didn't know, the B6 changed in '94...
- umcamara
Actually it looks like I linked to the '95 manual. They both show the same order anyhow, but they're DEFINITELY not accurate for a '96 B6DE.
- Mx3TD
thats cool man, i got a 92 B6ME. haha and it works... and it starts so i think i did it right...
- money_greenmx3
the correct firing order for 94 95 1.6l dohc is 1243 clockwise it should start from the top right cornerif You take ofur cap therotor should be pointing to the number 1 position.
- Ryan
No.money_greenmx3 wrote: if You take ofur cap therotor should be pointing to the number 1 position.
It will be pointing wherever the motor stopped. Could be anywhere.
