i can rembmer about a year or so ago reading something on this forums about an obd2-obd1 adapter harness was this ever manufactured and if so can u point me in the right direction buy one or if not maybe a mx-6 ecu i could get chipped any help would be greatly appreciated thanks,
1998 klze with k8 ecu help please.
kami_no_michi
well i decided to buy a new car while i was rebuilding my other. so i decided to get another klze mx-3 heh
anyway. problem is its a 1998 mx-3 with a ze and its got the 4 plug ecu. and basically the milleage sucks balls and i cant use my kl31 ecu in my other mx-3 so i was wondering wot can i do to change ecu bar ripping out the whole engine wiriring loom (because i dont know how to do it and dont really want to do)
Let them hate as long as they fear.
Re: 1998 klze with k8 ecu help please.
There's no harness available. Just use the KL02 VAF and your engine will run properly.
kami_no_michi
huh mean use the kl02 vaf with k8 ecu or use mx6 ecu with the mx6 vaf?
- Newfie_dan
kl02 with the k8 ecu if its an obd2 mx3 then it will run a klze properly minus the vris points with a kl02 vaf, the obd2 will adjust the fuel properly with the kl02 vaf in place of your stock vaf.
