I was wondering if someone knows if a radiator from a V6 MX-3 fits on a 4 cyl. I have a 1.6 DOCH and I want it to run cooler to see if I get a bettter performance. IF not, which radiator should I use
HOpe to hear from someone soon
I don't think you will gain much performance from a v6 rad, even if it does fit (which I think it does). Your better off looking at other options for performance.KYC15 wrote:Greetings
I was wondering if someone knows if a radiator from a V6 MX-3 fits on a 4 cyl. I have a 1.6 DOCH and I want it to run cooler to see if I get a bettter performance. IF not, which radiator should I use![]()
Ummm... get the thermostat that is specified for your model car, and get the lowest temperature one available.KYC15 wrote:Thank you for your answers. Ill see what else can I do
IF I change the thermostat, which one should fit that could run cooler?
