I just swapped my automatic tranny with a manual tranny and am wondering what each sensor on the manual tranny is for and which is which. there are three of them and one of them matches up with a plug that goes to the car. the other two sensors have different color wires than the automatic does and im not sure what plug each one goes to... ive tried to look up wiring diagrams and cant seem to find anything...
- just thought of this. would the sensors on the automatic fit in the manual? then i could just swap the sensors and be done...
thanks!
transmission swap automatic to manual wiring problem??
- Newfie_dan
Re: transmission swap automatic to manual wiring problem??
If the tooth count of the speedo gears are the same then yes you can swap the gears and use the stock wires, on the manual trans you have 2 sensors, the backup and speed sensor and neutral switch, in order to make the car work you will need to bypass the neutral safety switch to make the car work and wire up the backup sensor to the neutral safety switch for backup lights. FYI this has been covered extensively before in the transmission section.
- Ryan
small correction. Neutral switch is a cruise control thing ONLY. the ignition relies on the starter interlock switch, found on the clutch pedal.
the reverse switch operates the reverse lights.
Check the online manuals to see which is which.
http://www.mx-3.com/manuals/index.php" onclick="window.open(this.href);return false;
