Auto compatibility
Posted: January 10th, 2010, 7:52 pm
by 93Colttsi
My car is a 92' V6 auto car and i need to replace the transmission.
The local junkyard has a 94 (build date december 93) automatic v6 Mx3 with low km's...
The junkyard said that the tranny in that car wont work as its a 94 and the 92-93 automatic v6 trannys are different.
Is the junkyard wrong? Or can i ONLY use a 92-93 auto tranny. Im hoping the one from this 94 car will work!
I thought they were all the same for any years of the mx3 v6 auto trannys.
Some help would be awesome mx3 guru's!
Re: Auto compatibility
Posted: January 11th, 2010, 10:33 am
by 93Colttsi
okay well no responce.
I wanna pull this tranny out tomorrow... I want to make sure it will work
Arn't 92-98 MX3 k8 auto trannys all the same?
Posted: January 11th, 2010, 12:55 pm
by Nd4SpdSe
You can only use the V6 Mx-3 trans, nothing else, but 92-98 they're all the same.
Posted: January 11th, 2010, 9:33 pm
by 93Colttsi
Okay, right on, so it will work then. Thats all i needed to know!!
Posted: January 11th, 2010, 11:48 pm
by umcamara
Nd4SpdSe wrote:You can only use the V6 Mx-3 trans, nothing else, but 92-98 they're all the same.
Mmmm... not too sure about that. Don't forget he's talking automatic. I was under the impression that they don't work, as far as different number of sensors and what-not. I think u should do a bit more research first.
Forgive me if I'm wrong, but I have a feeling I might be right.
Posted: January 12th, 2010, 2:53 am
by 93Colttsi
hrrmm well hopefully the 94 car as the same tranny as the 92 im putting it in.
I seen on some website where i said the tranny was the same from 92-95
Posted: May 21st, 2010, 2:59 am
by 93Colttsi
Well I FINALLY got the tranny in.
Had to swap a few sensors over from the old tranny to the new tranny as they were different.
The Neutral saftey switch... and the reverse sensor i think?? both had different plugs but i was able to easily swap the sensors over and get them to work properly.!!
Posted: October 8th, 2010, 3:25 am
by 93Colttsi
Tranny is still in and working awesome !! yay
