My car is a 92' V6 auto car and i need to replace the transmission.
The local junkyard has a 94 (build date december 93) automatic v6 Mx3 with low km's...
The junkyard said that the tranny in that car wont work as its a 94 and the 92-93 automatic v6 trannys are different.
Is the junkyard wrong? Or can i ONLY use a 92-93 auto tranny. Im hoping the one from this 94 car will work!
I thought they were all the same for any years of the mx3 v6 auto trannys.
Some help would be awesome mx3 guru's!
Auto compatibility
Re: Auto compatibility
okay well no responce.
I wanna pull this tranny out tomorrow... I want to make sure it will work
Arn't 92-98 MX3 k8 auto trannys all the same?
You can only use the V6 Mx-3 trans, nothing else, but 92-98 they're all the same.
Okay, right on, so it will work then. Thats all i needed to know!!
- umcamara
Mmmm... not too sure about that. Don't forget he's talking automatic. I was under the impression that they don't work, as far as different number of sensors and what-not. I think u should do a bit more research first.Nd4SpdSe wrote:You can only use the V6 Mx-3 trans, nothing else, but 92-98 they're all the same.
Forgive me if I'm wrong, but I have a feeling I might be right.
hrrmm well hopefully the 94 car as the same tranny as the 92 im putting it in.
I seen on some website where i said the tranny was the same from 92-95
Well I FINALLY got the tranny in.
Had to swap a few sensors over from the old tranny to the new tranny as they were different.
The Neutral saftey switch... and the reverse sensor i think?? both had different plugs but i was able to easily swap the sensors over and get them to work properly.!!
Tranny is still in and working awesome !! yay
