EGR valves, are they interchangable??
mikeetown
Post by mikeetown »
So, i found out what was broken on my K8, and fixed everything. Was very cheap to do all this. But, i found out the main reason for my torque being bad is probably my busted EGR valve.
Are EGR valve from KL-DE's interchangable with K8-DE's???? (ford probe vs mx6 vs mx3??)
Are there any cars I can get this from????
mikeetown
93 Black GS - J-spec KLDE, CLEAN CAR
92 Red GS - J-spec K8ZE, stripped interior - Written off
2004 Infinity G35 Track Edition - 6 speed manual
viewtopic.php?f=17&t=79142
Slammed6
Re: EGR valves, are they interchangable??
Post by Slammed6 »
They are the same as long as you keep it OBD-I to ODB-I. I don't remeber if the OBD-II is the same but I know for a fact the OBD-I's are
mikeetown
Post by mikeetown »
nice!, problem solved. Thanks man.
mikeetown
OBD1 OBD2 EGR's? Are your totally uninformed?
mikeetown
Post by mikeetown »
i am. No one taught me anything about cars at all. Im poor so i just make myself learn to fix things and ask tons of questions. Been doing it since ive been 17.
mikeetown
mikeetown
Post by mikeetown »
i got one off a 93 mx3 with only 155,000 km on it( i would take the block but its half missing and i have no garage) and the egr valve from this made it worse??? I wonder if its the egr vacume sensor which i will prob do next. I even cleaned the newer EGR valve with a whole can of carb clean.
mikeetown
Slammed6
Post by Slammed6 »
Do you have any Check engine light codes?
Just because the CEL is not on does not mean the ECU is not having a code. Try pulling codes and see if it tells you anything.
ninja_man
Post by ninja_man »
so i am getting a cel on my car thay i just put the klde moter in. its for the egr. can i take the one off the k8 and it work. and y dose auto zone have 2 diffent part numbers for that pice on diffent cars
93 mx-3 with a klde swap. still working on
94 cobra svt. mostly stock.
08 ninja. 1 wheel fun. lol
Slammed6
Post by Slammed6 »
Your K8 one will bolt on and hook up to your KLDE motor.
