So im scrapping my car
Well, the depressing time has come that my destroyed underbody has ruined my car.
I took it into the shop for a leaking gas filler neck
And to check my brakes
Ends up I needed:
Both front tie rods
Both front ball joints
Both front axles
Both front wheel bearings
Gas Neck
Gas Tank
And full brake lines from front to back
And this is just taking a stab at all the s--- that is wrong with it.
I will likely be starting to part it out, although im looking into getting another MX-3 so..
Anyway, RIP my beautiful red GS baby.
Ends up I needed:
Both front tie rods
Both front axles
Gas Neck
Gas Tank
92' Red GS - RIP
93' Black Miata LE
93' Black Miata LE
- Ryan
Re: So im scrapping my car
Did you check these things yourself? Maybe the shop is just screwing with you.
Naw man, its true. I was watching him shake the wheel sde to side, and i knew it was like that. all the ball joints are making noise when i turn its fucked up...
The underbody is So. So bad. its.......done. my baby :'(
92' Red GS - RIP
93' Black Miata LE
93' Black Miata LE
- Ryan
Terrible news. May as well take off the worthwhile parts before you scrap her...
for sure got a decent bit of stuff a mint condition gs lip tails reverse gauges wrap around spoliers (3) 5 spoke rims so hopefully i can fund buying a new mx3 i love it too much, and this ones automatic so im buying a 5 speed for sure.
92' Red GS - RIP
93' Black Miata LE
93' Black Miata LE
Will you be parting out? Because I need some things if they're in good condition.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated
-- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
- mitmaks
doesn't sound like it would be too hard to fix. Of course you would need to posses some mechanical skills.
A completely new car with non-crappy locks....waspone wrote:what do u need?
Even my locks are wacked, my key is bent beyond repair i would carry one for the door and a straight one for the ignition, my locks would bend a straight key before it would work...lmao
im so rattled i dont know wht to do now im taking apart my car and its so depressing, dont feel like taking the bus to college and wasting the five hundred dollars i payed for a parking pass.....
hmph. fml
hmph. fml
92' Red GS - RIP
93' Black Miata LE
93' Black Miata LE
I need a bunch of brake hardware and the ebrake cables so far.
But it does suck having your car fall apart on you, mine's going through a rough time now too. Needs new rear hubs and the front suspension is making a ton of scary noises (clunks, rattles, scraping sounds and a sound that sounds like a deflated tire rubbing something, even though the wheels are tires are fine.
And Flyer, why do yo have to rub it in all the time? Man I don't pick on your car lol.
jmdearras
waspone wrote:Even my locks are wacked, my key is bent beyond repair i would carry one for the door and a straight one for the ignition, my locks would bend a straight key before it would work...lmao
A squirt of WD-40 will probably fix the door lock, worked for me on two MX-3s.
Jim
- Inodoro Pereyra
Waspone: too bad you live so far away from me, or I would be buying the whole body from you.
I've been trying to get a GS for months now...those cars are getting quite rare...
Diogenes of Sinope.
Diogenes of Sinope.
yeah i tried all kinds of stuff for the locks oenetrating oil etc. thats the least of my worries
indro, the body is no good, not worth ur time
92' Red GS - RIP
93' Black Miata LE
93' Black Miata LE
- Inodoro Pereyra
As long as it's straight and the panels are not damaged, it'd be perfect. I'm not worried about the structure, as it'd be getting a tubular chassis.
Anyways...you live in Toronto, I live in Miami...ugh...
Diogenes of Sinope.
Diogenes of Sinope.
