crank or what
Posted: August 31st, 2009, 5:18 pm
dose the crank sensor or is there another sensor other then the ecm that tells the injectors when to fire. my injectors are opening if u test them but put them on the car and thay wont open. the wires from the injectors to the ecm are good i have already tested that
