crank or what
crank or what
dose the crank sensor or is there another sensor other then the ecm that tells the injectors when to fire. my injectors are opening if u test them but put them on the car and thay wont open. the wires from the injectors to the ecm are good i have already tested that
93 mx-3 with a klde swap. still working on
94 cobra svt. mostly stock.
08 ninja. 1 wheel fun. lol
- msd-supermx3
Re: crank or what
Hey have u tried pulling your codes???? Fuel issue can be coming from many other factors... pull ur codes.... let us know
