block heater
block heater
ok so i live in clagary and all last winter i habd no block heater so this summer im plan on swapen the ze into my gs but is there anyway i can put a blockheater on the ze?
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
- umcamara
Re: block heater
I'd imagine there'd be a plug in the block near the firewall or something that you could remove, after draining the coolant, and install a block heater.
Not sure though. Don't even know what the climate is like in Japan. I'm that ignorant.![Embarassed :oops:](./images/smilies/icon_redface.gif)
Re: block heater
were is it on the k8 it might be the same ![Shrug :shrug:](./images/smilies/shrug.gif)
- umcamara
Re: block heater
I'm pretty sure it's on the side of the block that faces the firewall.
I'll check when I'm at the shop tomorrow night.
- Ryan
Re: block heater
I would think wherever there is a frost plug you could fit a heater... I'd love to have one on the front of the engine. Not sure though. The blocks are entirely different, right? (naive 4 cyl guy) Because then the passages will also be different...
Please let us know when you get one in...
It snows in Japan.
It snows in Japan.
