how do I remove the stock deck?
Car Stereo/Alarm Discussions
dash
Post by dash »
that is, without mangleage and destruction?
yes i know; i ask noob questions. :oops:
Who else drives a stock silver 94 GS?
VANCOUVER, BC, CANADA
umcamara
Re: how do I remove the stock deck?
Post by umcamara »
Pull out the ashtray and remove the phillips-head screw.
Remove the plastic bezel that surrounds the shifter and includes the part that the ashtray slides into.
Remove the plastic panel that runs parallel to the driver's door between the door and the dash.
Remove the plastic panel that your knees would normally hit, there's roughly 2 or 3 phillips-head screws, 2 at the bottom, and 1 or 2 where the last plastic panel was.
Remove the plastic bezel that surrounds the dash cluster. Theres 2 srews at the top of the bezel, 2 directly under those, 2 near your knees, and 1 or 2 around where the radio is.
Now you can remove the screws and pull the radio out.
'98 BMW 328is M-Tech
Feedback Thread
dash
Post by dash »
umcamara wrote:Pull out the ashtray and remove the phillips-head screw.
and i have to remove all of that stuff to get at the deck?
no shortcuts?
umcamara
Post by umcamara »
It's really quite easy to take that stuff apart.
However, not having had a stock head unit in the car when I bought it, I hadn't realized that you don't need to do that. The stock radio has 4 holes at each corner in the front, they should be covered by llittle plastic inserts. You need to gently pry those out. You can then insert 4 long skinny nails, or anything else you might have that fits, but it has to have pretty good bending strength because otherwise they'll just bend during the next step.
With all whatevers in the holes, pull the two on the left side towards the left, and the two on the right side towards the right at the same time. While doing this pull all the whatevers towards you.
There are radio removal tools for doing this, but they're not necessary. Ford, Volvo, Volkswagon, and I'm not sure who else use the same system in many of their cars.
Feedback Thread
dash
Post by dash »
umcamara wrote:It's really quite easy to take that stuff apart.
oh righteous!
i saw those little holes and thought: these have to be relevant.
but im lazy and just came and asked you guys. :shrug:
Mad Cow
Post by Mad Cow »
I tried using a bent-up coathanger when taking the deck out of my parent's ford and it just didn't work, I struggled for a good half-hour before I gave up and just bought a set of remover tools for $5. When I took the deck out I realized that it would be next to impossible to pull that certain one out with anything but the remover tools because of the design of the clips.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated :lol: -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
umcamara
Post by umcamara »
That could be, but the problem may be that a coat hanger is too ductile, it'll just deform when you push outwards in the holes. That's the reason why I suggested long nails, because they're case-hardened steel, and won't bend.
Feedback Thread
ninjajim4
Post by ninjajim4 »
uh... if you have a pocket in your second DIN, just pull it out and reach up and press the clips in, pull the radio out. 30 seconds.
xxwhiteboyjim22xx
Post by xxwhiteboyjim22xx »
Yea I just used 2 screw drivers, and it slid out with no problom.
projectzemx3
Post by projectzemx3 »
pull really hard
NEED PARTS INSTALLED? PM ME!
dash
Post by dash »
projectzemx3 wrote:pull really hard
ha ha.
muttpower
Post by muttpower »
I've fabricated the removal hooks with a coat hanger and some wire-cutters. And if all else fails, just blugen the f*ck out of it with a hammer. Hammers fix everything. :lol:
1992 MX3 GS (My Project Toy)
K8DE, see web site...too many mods to list, but still growing.
2006 Dodge Durango (The Family-Mobile)
Every time you race a Honda Civic, a kitten kills a retard.
Sheen
Post by Sheen »
First, remove the two plastic hole covers on the left and right sides of the radio. They are about half and inch wide; just jiggle and pry them out. Then you will see the holes where you insert what are called "radio removal keys." On either side there are two small holes separated by an elongated hole. Insert two of the radio removal keys, one in each set of the small holes.
You will need two of the U shaped tools, one for either side of the radio. Alternatively, you can make U-shaped tools out of lengths of still coat hanger. Cut them about four inches long, then bend them into a "U" shape with the points as far apart as the holes in the radio. Insert them until you hear a click, then push the left one to the left and the right one to the right. This will depress the clips that hold the radio in. While you're holding the clips out, pull on them and the radio should slide right out.
umcamara
Post by umcamara »
Do you have any concept of time??
Feedback Thread
MrMazda92
Post by MrMazda92 »
umcamara wrote:Do you have any concept of time??
Judging by his post count, he's new to the forum. Possibly to forums in general? Cut him some slack, we all have to start somewhere.
Return to “Car Stereo/Alarm”
