K8 into Probe
xSocialx
K8 into Probe
Post by xSocialx »
Hey all!
Do you think that a K8 from a MX will fit into a probe that has a ZE?
I know it would take work but I'm willing. Any info would help.
Thanks,
onlytrueromeo
Re: K8 into Probe
Post by onlytrueromeo »
If you can go DE into MX3 you can go k8 into probe...won't be that hard...but the question is why? It will be slow as balls! DE has more HP than K8, and the probe is heavier than the mx3.
DE's are cheap, just get another one!
If you have a free k8 and don't wanna shell out money, just keep the probe mounts and tranny. Everything should fit fine...sensors might be your only trouble depending on what year the car/motor are.
xSocialx
Re: K8 into Probe
Post by xSocialx »
Well the probe has a ZE and my car is a 94'.
The reason why I am askin if I can put the K8 into the probe is a long story but it makes sense.
Ryan
Re: K8 into Probe
Post by Ryan »
I don't know why people ask these questions.
Its like those little shape puzzles you get when you are one or two years old.
If you can put the circle through the circle hole, you could put the hole around the circle.
If it works one way, it obviously works the other.
xSocialx
Re: K8 into Probe
Post by xSocialx »
Thanks for your input.
Did you think about wiring? What ECU to use?
Ryan
Re: K8 into Probe
Post by Ryan »
I've never done a DE/ZE swap, but as far as everyone else says, the wiring is the same between certian compatable years (OBDI/OBDII).
Since its a K8, I'd use the K8 ECM. Probably along with its respective VAF/MAF and other such sensors...
Its just the reverse of what we normally do. If you do a DE swap, you'll know how to do a K8 swap.
I guess the only thing I'd wonder about is if you must use certain parts for both swaps, like a halfshaft.
RS_OBD'oh_2
Re: K8 into Probe
Post by RS_OBD'oh_2 »
poles and holes lol :lol:
Well, I really want to know why. I'm sure it's a long story and what not... but I just cannot understand why someone would do and engine swap to make their car slower?
Re: K8 into Probe
If you can get a K8 for like, Free, than ya, but for the most part, DE's are much more available, thus cheaper to get.
klmx08
Re: K8 into Probe
Post by klmx08 »
hes right man a de is 35-40 hp more and more available and that means cheaper
Flyer
Re: K8 into Probe
Post by Flyer »
Probably just needs the old K8 in the doner Probe so it can still be driven off a cliff...
projectzemx3
Re: K8 into Probe
Post by projectzemx3 »
lmao
buy a mx3, buy a probe,
switch the engines and put the de IM on the K8 as well as the ford valve cover.... HAHHAHAHAHAH sell the probe. drive the mx3.
NEED PARTS INSTALLED? PM ME!
Re: K8 into Probe
Swap the ECU for a K8 and the VAF for a JE50 both of which I just happen to have. :)
If this was a [FS] post I would probably say $50 for the VAF and $50 for the ECU but since this isn't a [FS] post I can't comment. Oh Shipping is on top of that. lol
xSocialx
Re: K8 into Probe
Post by xSocialx »
Well it was a questions for if a deal went through with t-mac.
The probe had a DE in it and I wanted to buy the car swap the K8 with the ZE then sell the probe.
But I would sell a car faster (especially a probe) if it had an engine in it. Hence the K8.
But it doesn't matter now, cause the car was sold. :evil: :evil:
projectzemx3
Re: K8 into Probe
lol who ever would buy that probe would get so screwed hahaha im going to buy a probe now and do that just for fun.
Daveb
Re: K8 into Probe
Post by Daveb »
I was gonna do the same thing but the Probe had a KLZE. I was looking forward to shafting some ford guy :lol:
