1.6 sohc distributor
Posted: April 12th, 2009, 4:35 pm
by shinsonater
from what car can i pull an upgrade for the 1.6 sohc?
Re: 1.6 sohc distributor
Posted: April 12th, 2009, 6:49 pm
by Limegreen mx-3
that part u really can't other parts of ur sohc u can upgrade.. but u won't get a big difference in power..
Posted: April 14th, 2009, 9:53 pm
by shinsonater
so as far as your concerned whats the best things to do for the sohc? do you know of any after market cams?
Posted: May 11th, 2009, 9:15 am
by Redline322
There isnt much at all for the 1.6 sohc except plugs, wires, cone filter, coil. If you are looking for power, you are better off swapping in a BP. 40hp for around $500 for the swap is better than spending roughly $200 for a cam that will get you maybe 5-10hp.
