my mx-3 wont start please help me !!!!!
Posted: March 29th, 2009, 5:50 am
by mcbridedarnell
this is what is going on one day it was running fine then it went crazy when I would give it gas it would want to die but only if you romp down on the gas pedal it is alright if you take it slow when pushing on the gas pedal but now it will only start sometimes it just cranks over and over the times it dont start. But if I leave it set a day or two it will start right up its getting fire and it's getting gas please someone help me
Re: my mx-3 wont start please help me !!!!!
Posted: March 29th, 2009, 12:22 pm
by johnmx3ze
mcbridedarnell wrote:this is what is going on one day it was running fine then it went crazy when I would give it gas it would want to die but only if you romp down on the gas pedal it is alright if you take it slow when pushing on the gas pedal but now it will only start sometimes it just cranks over and over the times it dont start. But if I leave it set a day or two it will start right up its getting fire and it's getting gas please someone help me
i think its time for the HEI mod... search it
Posted: March 30th, 2009, 11:00 am
by Tommy
or you could just replace ICM
Posted: March 30th, 2009, 11:33 am
by 69shelby
TPS sensor might be bad?
Posted: March 30th, 2009, 12:20 pm
by Tommy
also it could be your Crank shaft positioning sensor
Posted: March 30th, 2009, 12:24 pm
by projectzemx3
im leaning more towards the disty as well.
Posted: March 30th, 2009, 10:18 pm
by mcbridedarnell
But Im still getting fire
Posted: March 30th, 2009, 10:31 pm
by johnmx3ze
i would check...
vaf if not stuck closed, happened to me
plugs
fuses
fuel pump
timing
Posted: March 30th, 2009, 11:08 pm
by Daninski
Umm hard to help with that type of info. Try to be a little more specific and less,,,,hip. What does it do, when and what effects it.
