my mx-3 wont start please help me !!!!!
this is what is going on one day it was running fine then it went crazy when I would give it gas it would want to die but only if you romp down on the gas pedal it is alright if you take it slow when pushing on the gas pedal but now it will only start sometimes it just cranks over and over the times it dont start. But if I leave it set a day or two it will start right up its getting fire and it's getting gas please someone help me
- johnmx3ze
Re: my mx-3 wont start please help me !!!!!
mcbridedarnell wrote:this is what is going on one day it was running fine then it went crazy when I would give it gas it would want to die but only if you romp down on the gas pedal it is alright if you take it slow when pushing on the gas pedal but now it will only start sometimes it just cranks over and over the times it dont start. But if I leave it set a day or two it will start right up its getting fire and it's getting gas please someone help me
i think its time for the HEI mod... search it
or you could just replace ICM
TPS sensor might be bad?
also it could be your Crank shaft positioning sensor
NEED PARTS INSTALLED? PM ME!
But Im still getting fire
- johnmx3ze
i would check...
vaf if not stuck closed, happened to me
plugs
fuses
fuel pump
timing
plugs
fuses
fuel pump
timing
Umm hard to help with that type of info. Try to be a little more specific and less,,,,hip. What does it do, when and what effects it.mcbridedarnell wrote:this is what is going on one day it was running fine then it went crazy when I would give it gas it would want to die but only if you romp down on the gas pedal it is alright if you take it slow when pushing on the gas pedal but now it will only start sometimes it just cranks over and over the times it dont start. But if I leave it set a day or two it will start right up its getting fire and it's getting gas please someone help me
