best way to wire
mccabe
best way to wire
Post by mccabe »
so im about to swap in a klze into my gs and i wont to know what is the best way to put on the harness before or after its in? and any tips to wireing it. :shrug:
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Newfie_dan
Re: best way to wire
Post by Newfie_dan »
you don't need to swap the entire harness just extend a few of the wires. If you are swapping the entire harness then engine out is easier just make sure you know what goes where and know that the dash is going to have to come out. If you research the klze swap then you should have no problems finding info on the wiring end of it.
You don't need to extend anything. I didn't...I believe most don't. Everything on the block is in the exact same locations as the K8, the only thing you may possible need to be creative on is the vacuum lines if using a different IM, but it's just vacuum lines.
onlytrueromeo
Post by onlytrueromeo »
I had to extend my IAC line and my knock sensor (knock sensor was on wrong side of engine, but I could have switched it if I removed the manifold)
mccabe
Post by mccabe »
i konw this isnt the sam question for this forum but how about ac i know thaT I keep the old compressr easy to do?
onlytrueromeo
There are 2 different compressors for the KLZE I found, I dont know if it changes in years on the mx3. I know my first ZE that went into my 92, the compressor didn't quite bolt up. The 2nd one fit fine though.
Slammed6
Post by Slammed6 »
you don't remove your A/C compressor from the car. just unbolt the 4 12mm bolts that hold it to the bracket bolted to the motor, and swap bracket over to ZE motor, then once motor is back in car bolt the compressor's 4 12mm bolts back up the bracket.
wagZE
Post by wagZE »
Gyea, unbolt the thing and hold it up with duct tape or speaker wire or whatev u have. As far as wiring. Tip for wiring: Use wire loom everywhere when the motor is out, it is easier; you'll be glad you did as it will look way cleaner. Check your local car stereo shop for enough wire loom.
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
