ecu question
ecu question
so i have heard that when i order my klze it most likly wont come with an ecu. so my question is what ecu would i have to buy so that i DONT have to swap the wiring harness cause mine dosnt look that good.
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Re: ecu question
If you're car is OBDI - search
If you're car is OBDII - search
Re: ecu question
Since you apparently have a 1992 car in your sig, I think changing to a KL31 or KL36 is your answer. Almost everyone uses those unless they have OBDII.
1995 Eunos 30x KLZE
Re: ecu question
or you can get a chipable k8 ECU with the probinator chip ( which I happen to be selling)
PM me if you are interested in the ECU
Jesse<BR>red 92 gs
Re: ecu question
Feel the OBDII love...or lack of...makes me almost want to look for an OBDI car...RX8SE3P wrote:Since you apparently have a 1992 car in your sig, I think changing to a KL31 or KL36 is your answer. Almost everyone uses those unless they have OBDII.
