Ok... So, I get in my car in the morning. Crank it up, and everything is fine.
I start going down the road and as soon as I push the gas down alittle to get up some speed, it basiclly goes no where, like it kinda lost almost all it's power just for a second. Then, It jerks like 2 times. I let off the gas, then press it down again and it doesn't do it anymore. It usally does it when it's cold and the drive after the first start up of the morning. What do you guys think this is?! - Has anyone had this problem?!
Thanks!
Stalling & jerking...
SmoothMX3
--- K8 was my gateway drug.
Re: Stalling & jerking...
Yes actually! When I got my car this summer. it happened quite a bit, especially sitting at a red light than taking off. I drive a 93 1.6 soch. I took out my spark plugs and came to find out they were all shot. (3 broke as i was taking them out) I purchased regular NGK's threw them in and my problem dissapeared. Have you tried this yet?
~Rocky
~Rocky
CF Hood, Kenwood everything, 2.25 catback exhaust, H&R Springs, F&B Strut bars
My worklog: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=68856" onclick="window.open(this.href);return false;
Good afternoon from the biggest Douch around;D
- Ryan
The only time I've seen that is when the battery was shot...
Your TPS could also be worn out.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated
-- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
SmoothMX3
Okie dokie... It will all be good tomorrow then. you'll see...
any luck?
SmoothMX3
I take it no one cought that remark. Notice my other thread "Might be a KLZE"!SmoothMX3 wrote:Okie dokie... It will all be good tomorrow then. you'll see...
Woot Woot!
what?? lol so did you fix it or not??SmoothMX3 wrote:I take it no one cought that remark. Notice my other thread "Might be a KLZE"!SmoothMX3 wrote:Okie dokie... It will all be good tomorrow then. you'll see...
Woot Woot!
