Remote starter works, but stops engine after 2-3 seconds
nightfire
Post by nightfire »
Hey guys.. I got my remote starter working, except that it kills the ignition after 2-3 seconds. It kills the starter as expected, right on time (as soon as the engine lights up), the idle starts to settle, then bam.. cuts the engine.
I've been trying to figure it out for an hour now. Does this problem sound familiar to anyone? Any suggestions?
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
Re: Remote starter works, but stops engine after 2-3 seconds
Shut off timer? maybe you have it set to seconds rather than minutes?
nightfire
Post by nightfire »
Nd4SpdSe wrote:Shut off timer? maybe you have it set to seconds rather than minutes?
Good thinking, but there's only 2 settings (5/15 minutes iirc).
- Gord
nightfire
Post by nightfire »
Bah. Found the problem. It was that shitty carvox unit.
The resistor they used on the sense line was either too low current, or too low resistance. It melted. I changed it for a 13.2kOhm 1/4 watt and it's working perfectly now. Yay remote start. :)
- Gord
