bulb covers, changing color
i have been all over the place trying to find those little slip on covers to replace the stock green one on the bulbs behind the guages..i found one place in kitchener that sold them in packs of 3 for 7 bucks a pack
...seems a little pricey for what they are, plus they didnt have the color i wanted..anyone know where i could find these for a reasonable price? ebay is last resort...my plan is to replace the stock green with blue
- Ryan
Re: bulb covers, changing color
Neons came with little blue condoms on their bulbs. Same size, too.
Pocket loot.
Pocket loot.
- solo_ryder
They dont have em in blue though... do they? I thought old neons had yellow and new ones green
- Ryan
Well I got blue ones from a Dodge version. I can't recall the year. I believe it had a single centred speedo, and was an automatic.
I have a 12v battery I made. I used a 9v and two D cells wired in series to make 12v. The current abilities are low, but it makes sparks. I can power horns and I would assume some cluster lights, if you could find the relay.
If the bulbs are 194, toyota's came with the blue condoms on them. You can also get them from a toyota dealer.
Chris
Chris
I remember someone posting links to colored LED replacement bulbs....
i searchedNd4SpdSe wrote:I remember someone posting links to colored LED replacement bulbs....
- solo_ryder
I know that you can get replacement bulbs for a PGT... through probeaddiction.. Not sure if they would all work
Couldn't find anything on the site, but i searched the web
http://www.ledshoponline.com/automotive ... d_bulb.htm" onclick="window.open(this.href);return false;
http://www.ultraleds.co.uk/automotive-b ... 1_142.html" onclick="window.open(this.href);return false;
I know they're out there,,,just need to find them
- solo_ryder
I've used http://www.autolumination.com" onclick="window.open(this.href);return false; and had pretty good luck with LED's... I've had some for over 5 years now and still work fine
also if you want some little condom caps I still have this bunch I'm not using... let me know if you are interested... took me forever to find them online. I used the red ones in my cluster on page 2 of my daily driver worklog. I didn't like the blue since it makes them a little washed out...
what do u want for them moon?
and did you try them with the stock guages at all?
