here is a an image of it
i found it by searching "mx3 filter" on eBay
Yoda had that on his car, just before the TB. The venturi effect can increase exhaust speed, too. I don't know enough about it, and hate doing formulas, but I would LDaninski wrote:OK, I have a Jesse idea. We've used venturi air movers that are very efficient. For every cu.ft. of air you put in 25 cubic feet come out. So if you have a source of compressed air you could use this venturi to ram charge your intake. Varying the air you put it varyies the total output. Now, where to get the pressurized half from. The unit I'm speaking of is the size of your VAF. How cool is that.
