clunking noise 93 mx-3
hi i have a 93 mx3 gs. the right front wheel has a bad clunking noise when i turn left or right only. and when i let off the gas or somtimes out of nowhere the steering wheel will start shaking really bad and will pull hard to the right. so if anyone knows what the problem could be plz let me know i could really use some help thatnks.
projectzemx3
Re: clunking noise 93 mx-3
hahaha are you serious??
wheel bearing, inner tie rod, outer tie rod, ball joint, broken stabilizer link, control arm bushing, broken spring, upper strut mounting plate broken. lol have you even jacked it up and shook the wheel yet?
NEED PARTS INSTALLED? PM ME!
not yet it just happened last night but i will do that.
