im planning on installing fog lights, but first i want to know all the steps. does sumbody have a walkthrough or pictureson how to install them.
oh and what is the best place to tap into a wire for the power?
thanks guys
fog light install
Re: fog light install
What kind of fog lights? What kind of bumper do you have? Where do you want to put them?
I think I stole the power from the fuses in the engine bay, either ABS or A/C, Don't remember, but I have neither. Ideally, wiring in a switched relay that's tapped into the parking lights, so you can only turn them on with at least the parking lights on.
http://shop.advanceautoparts.com/produc ... Code=3151F" onclick="window.open(this.href);return false;
these are the lights im planning on using, oh and i have the stock bumper, and im planning on putting them in the bottom lip of the mouth (the missing parts that looks like a mouth, for airflow to the radiator)
how would i go about tapping into the fuses or relays, i havent done this before and i dont want to mess up the wiring ir fuse/relay block, could you give me a step by step walkthrough on how to go about it?
tom
- Newfie_dan
almost all fog lights come with the wiring required such as relays and switches/fuses. Just remember that when tapping into wiring use proper wiring not farmer wiring or ghetto wiring. Piggyback fuses are available to use for tapping into a single fuse holder and using it to supply 2 fuses (1 for the original source and 1 for your source) without causing any damage. Never run a direct 12 volt source without a fuse in that circuit. If you need I can supply you with a basic schematic for a fog light system. FYI use a dedicated relay for the fog lights don't tap into factory relays for it unless they are meant for it. Check out this link for a wiring schematic. http://www.classictruckshop.com/clubs/e ... glites.htm. My only beef is that they don't show a fuse on the switch side between the switch and the power source, which should be there.
I've only got one suggestion for a change to that diagram. I wired mine exactly like that with one exception. If you pull the power for the switched coil on the relay from the interior light circuit, then your fogs will only come on with the headlights. I added that little change after I left the damn things on and drained my battery a couple times.
I tapped mine into the running lights, so I can turn them on with at least the running lights, headlights could actually be off.
