why do i need starter fluid?!
Posted: December 2nd, 2008, 10:50 pm
by Gods Father
i recently finished my ZE swap and the only wayi can start it is if i use starter fluid...once it runs for a while i can shut it off and turn it back on with out it...i can let it rest for maybe an hour before i need to use the fluid again...any ideas?
Re: why do i need starter fluid?!
Posted: December 4th, 2008, 3:05 pm
by hgallegos915
No fuel.
check conections
Posted: December 4th, 2008, 9:46 pm
by Gods Father
well once it starts it runs...so i dont know...what connections?
Posted: December 4th, 2008, 10:30 pm
by onlytrueromeo
Did you replace the fuel filter? Are your fuel lines bent or are the rubber ones pinched?
Posted: December 6th, 2008, 10:45 am
by Gods Father
yea i replaced the fuel filter and im pretty sure none of my lines are bent ill double check...it just doesnt make sense why it will continue to run and start up after its been running but going from a cold start it needs the fluid...
Posted: December 6th, 2008, 7:44 pm
by fowljesse
Maybe for some reason it doesn't go into start mode?
Posted: December 6th, 2008, 9:31 pm
by wytbishop
Low fuel pressure. Check your FPR. Could also be the pump but unlikely as I'm sure you didn't do anything to it.
