why do i need starter fluid?!
Gods Father
Post by Gods Father »
i recently finished my ZE swap and the only wayi can start it is if i use starter fluid...once it runs for a while i can shut it off and turn it back on with out it...i can let it rest for maybe an hour before i need to use the fluid again...any ideas?
1993 MX-3 w/ straight neck KLZE swap...Probe GT 2.5in headers, Custom exhaust w/ test pipe and OBX Twin Loop Tip, Bully Stage 3 Clutch, Fidanza Flywheel, Pheno Spacers, HEI mod, Blaster SS coil, Probinator chip, TWM short shifter, AWR front and rear mounts (88 Durometer), and Corksport braided clutch line...so far
Ever see the lone rider of the night? Well he'll find you and then you'll never him again...
hgallegos915
Re: why do i need starter fluid?!
Post by hgallegos915 »
No fuel.
check conections
-hec
Gods Father
well once it starts it runs...so i dont know...what connections?
onlytrueromeo
Post by onlytrueromeo »
Did you replace the fuel filter? Are your fuel lines bent or are the rubber ones pinched?
Gods Father
yea i replaced the fuel filter and im pretty sure none of my lines are bent ill double check...it just doesnt make sense why it will continue to run and start up after its been running but going from a cold start it needs the fluid...
fowljesse
Post by fowljesse »
Maybe for some reason it doesn't go into start mode?
Post by wytbishop »
Low fuel pressure. Check your FPR. Could also be the pump but unlikely as I'm sure you didn't do anything to it.
