wen i take it off from the top (the intake manifold side) it looks blocked on the inside about an inch into the hose, can i clean this out so its just a straight through hose or is it part of the breather assembly
wats this hose do
- solo_ryder
Re: wats this hose do
Its the PCV hose, goes between the valvecover and Intake mani as a breather. The hose should be clear
