fuel adjust screw?
fuel adjust screw?
is there a screw to adjust the fuel; like the idle air adjust screw but for the fuel. mi uncle had a look at mi car today and was trying to find it but cudnt, he says every car shud have 1. im not sure ay, i always thought wen u lift the idle screw, it opens the tb slightly which then sends a signal to the ecu to give it more fuel too. so to summarize it : can i adjust the fuel getting let into the engine without communicating with the ecu (air/fuel ratios) and without adjusting the idle screw (on top of the throttle body) if so where is it!! lol
Re: fuel adjust screw?
lol fuel injected not carborator....
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
LOL There is no fuel adjustment screw, Why are you wanting to adjust the fuel anyways?
