4X4 MX-3?
- cjthor
4X4 MX-3?
Anyone ever thought of this? Not an AWD but rather putting an mx3 body on like a bronco or Jeep frame? Hmmmm my jeep needs a new body and I have this parts car mx3 at home.....
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- fowljesse
Re: 4X4 MX-3?
I'll help!
One of the coolest things I've seen was a Mercedes CLK on a Unimog frame! It was incredible!
If anyone doesn't know what these are, Google them! It's hilarious!
SmoothMX3
Re: 4X4 MX-3?
You guys are wild
--- K8 was my gateway drug.
Re: 4X4 MX-3?
I would definately help with this project!
I saw a first gen mitsubishi eclipse on a 4x4 frame in memphis jacked up on some 35's or something... pretty crazy...
lol that would at least put that mx-3 to good use instead of trashing it!
Re: 4X4 MX-3?
35's is over the top. You don't want it to look funny.
- cjthor
Re: 4X4 MX-3?
There are 35's on my jeep right now..thats what it would getwytbishop wrote:35's is over the top. You don't want it to look funny.
Jarid Perry
- cjthor
Re: 4X4 MX-3?
This means now i need ANOTHER set of doors!Mooneggs wrote:I would definately help with this project!
Jarid Perry
- fowljesse
Re: 4X4 MX-3?
Naw. Weld 'em up, Dukes of Hazzard style! We're Redneckin' it, anyway!
Re: 4X4 MX-3?
why? some jeeps don't have doors lolcjthor wrote: This means now i need ANOTHER set of doors!
Re: 4X4 MX-3?
Would be the simplest and cheapest of major mods. With trucks being a body-on-frame, taking the body off wouldn't be a problem, and it technically would still drive. The Mx-3, well, it's a unibody, so you'd just have to cut the body of the mx-3 to conform to the frame of the truck. If you have the doner vehicles, all it would take is time, a welder and a sawsall. The only thing you may need to do is adjust the rear wheels so that the front and the rear line up with the wheel wells of the mx-3, asthetically speaking.
http://www.jtruck.net/misc/4x4cars/" onclick="window.open(this.href);return false;
Re: 4X4 MX-3?
Ummm...I was kidding. Like..."How do you make an MX-3 body on a Jeep frame look funny?" It supplies it's own punchline.cjthor wrote:There are 35's on my jeep right now..thats what it would getwytbishop wrote:35's is over the top. You don't want it to look funny.
- mitmaks
Re: 4X4 MX-3?
that's what I wanted to say. You can't simply separate mx-3 from the frame since its unibody, good luck with project though.Nd4SpdSe wrote:Would be the simplest and cheapest of major mods. With trucks being a body-on-frame, taking the body off wouldn't be a problem, and it technically would still drive. The Mx-3, well, it's a unibody, so you'd just have to cut the body of the mx-3 to conform to the frame of the truck. If you have the doner vehicles, all it would take is time, a welder and a sawsall. The only thing you may need to do is adjust the rear wheels so that the front and the rear line up with the wheel wells of the mx-3, asthetically speaking.
Re: 4X4 MX-3?
Indeed, but the frame part would be something that would facilitate bolting it to the truck frame.mitmaks wrote:that's what I wanted to say. You can't simply separate mx-3 from the frame since its unibody, good luck with project though.
- cjthor
Re: 4X4 MX-3?
True...Just gona have to get the mx3 in the air and take a look at the subframes. Luckily I think Im about to buy a lift!!Nd4SpdSe wrote:Indeed, but the frame part would be something that would facilitate bolting it to the truck frame.mitmaks wrote:that's what I wanted to say. You can't simply separate mx-3 from the frame since its unibody, good luck with project though.
Jarid Perry
Re: 4X4 MX-3?
I'm quite curious on that as well. I'd like to see it to be a clean install and not look like it's literally a car bolted on a truck frame. I think what makes or breaks that is having the wheel wells go with the shape of the tires. I think the Fiero, Delorian and the baby blue Camaro are the perfect examples on what I hope it doesn't look like.
The nice thing is that you just need to give the fuse panel power and all your interior systems on the mx-3 would work as-is.
