KLZE'ing my 30x - Have got the engine in need a little help
Hi guys, take a look at the pics below and you can see I have put a straight neck ZE into my Eunos 30x (right hand drive mx3). All is going ok so far but I have a couple issues with the straight neck manifold. There's a few vacuum lines and whatnot on the K8 IM that are different or simply just not there on the ZE.
If anyone has done a straight neck swap, can they take a picture in the highest resolution they can and send it to me?
I'll also post some pics of spots I am having trouble with.
Also - this is important. I originally thought I had a OBDII car because it's 1995 and I swore the ECU had 4 slots on the back. I seem to be wrong. There's 3 slots. Also only two O2 sensors in the car. Pics are also below. This is OBDI isn't it?
Thanks heaps
Thanks heaps
1995 Eunos 30x KLZE
- Dragyn Vyrus
Re: KLZE'ing my 30x - Have got the engine in need a little help
For the time being you can check out my work log: http://www.mx-3.com/phpBB3/viewtopic.php?f=46&t=66007" onclick="window.open(this.href);return false;
it has some pics that might be able to help you out i think that those might both be for the brake booster, but i'll check and take some pics for you tomorrow for you when i get a chance.
and on another note, i want that engine! its sparkling! wish i wasn't so lazy and cleaned mine up before i tossed it in lol
93 MX-3 ZE-GS - Sold
95 MX-3 RS - Bone stock winter car.
92 JDM turbo MR2 - SSQV, Cusco strut tower bar, ATS intercooler kit, Berk Exhuast, HKS EVC-S
Thanks mate, will check out your pics. And yes it's for the brake booster I think. Mine is on the other side tho as I am right hand drive. If you could get some high res pics for me that would be great. I might have to PM you for some more stuff though hehe. Some more vacuum lines and whatnot are kind of not finding their place lol.
Btw thanks, my dad painted up the valve covers and intake for me, wish the internals of the engine were a little cleaner though. There's a bit a sludge and whatnot. Hopefully it will run fine!
1995 Eunos 30x KLZE
Hey in your thread you used the K8 throttle body right? I am trying to use the ZE throttle body but it's kind of not got the same amount of pipes and whatnot coming out.
Do people just use their K8 TBs? Or am I just tripping out and you can use the ZE TB?
1995 Eunos 30x KLZE
OBD1 and yes brake booster hose. Didn't your engine come with it's own throttle body?
- marcdh
Yep def OBDI, both my cars are 95, one with ZE, both OBDI.
That's the brake booster, straight neck should have a port that size on it, just might need longer hose.
The straight neck ZE TB will work fine. Just make sure you chip your ECU or get kl31/36 for correct running.
View Worklog
View Worklog
Thanks guys, yeah there is a port on the other side of the IM that is the same size, I am assuming it's for the brake booster as well.
My ZE does come with it's own TB. Just not on yet. There are some vacuum lines near the TB and IM that don't have a place to go. I will post some pics up after work today.
Thanks for the help so far
1995 Eunos 30x KLZE
Ok there's so many different pipes and stuff.... but I'm slowly figuring some stuff out. Found out some more plug locations but I want to confirm here too.
First up this is what I think is the break booster vacuum port. It's on the other side compared to the K8 IM.
So that might be one easy hose out the way.
This one is joint on the ZE as you can see. But there's two separate plugs from the K8 that go into it. I might just take it out and copy what was on the K8 IM. The plugs are in the exact same spot.
Now there's also this little bracket thing that was mounted on the back of the K8 IM. Here's a pic:
There's two plugs from the wiring loom that go to it. There also seems to be vacuum nipples on it. I can sort of half a-- dodgy it up and mount it to the back of the ZE and put the corresponding plugs in it.
1995 Eunos 30x KLZE
here you have a pithure of my straight neck klze:
http://www.garaget.org/?car=60659&image=1081103" onclick="window.open(this.href);return false;
Thanks poppsy. But do you reckon you could take any new high res pics of around the throttle body, air filter side?
Does anyone else want to comment on some of the pics I showed?
1995 Eunos 30x KLZE
RX8SE3P:
Yes, i can do that this week.
Post them here when I have done that.
No need to worry mate, I got it all figured out. Got my ZE started up for the first time last weekend.
1995 Eunos 30x KLZE
Those are the VRIS solenoids if I'm not mistaken, EGR solenoids look the same but if it's a klze then you wont have an EGR.Now there's also this little bracket thing that was mounted on the back of the K8 IM. Here's a pic:
Here is a picture that I snagged from my local librarys car repair website thing, might clear things up.
http://img363.imageshack.us/my.php?imag ... iagiw7.jpg
14.985@92.54 MPH
Red 93 MX-3 GS, KLZE, 5 speed, Act clutch, short throw shifter, HEI w/blaster 3 coil, PIAA ultra white headights, CAI, Apexi Dunk muffler w/2.5 inch cat back, Avital alarm, dark tint, Sony Xplode 52x4 head unit, Clarion speakers in the front, Pyramid 6x9's in the back, Volfenhag 2000 watt amp, 3x crappy MTX 10 inchers.
