[GI] Complete BP swap
Mazda_Powered
Post by Mazda_Powered »
If i can't sell my 323 by the end of the month i'll probably part it out.
Engine has around 120,000k. Tranny has around 180,000k. No smoking during start up, decel, WOT. Compression shows 176-178-180-178 so the engine has beautiful compression (180 new). All MAZDA. No Ford BP/tranny here.
Engine has new valve cover gasket, intake manifold, exhaust manifold, all OEM Mazda seals, i'd also come with OEM cam and crank seals (they dont leak)
Engine also has a 'cut'/ported/polished intake manifold.
Mazda BP wiring harness was stripped and re-loomed.
Axles are in great shape, no damage or clicking.
Transmission linkage is better than new, super tight!
I'd be looking for $700 OBO for the entire lot, I could deliver, but it would cost a bit more...
Located in London, on.
.::Mazda::speeD::.
working on the 2nd part ;)
Mazda_Powered
Re: [GI] Complete BP swap
also there are some 'extras' that would come with the swap.
-oem dual core rad
-adjustable fuel pressure regulator
-home made pcv filtertration system
-front strut bar
-spare coolant temp & thermo sensors (15,000k off my protege gt)
-2 spare throttle bodies
-2 oem cam seals
-1 oem outter crank seal
-1 used oem inner crank seal (15,000k off my protege gt)
-4 wire o2 sensor conversion (hard wired right now, making a plug system as we speak)
-upgraded ground wires
-filled rear mount
-spare front mount w/ poly caulking.
.::Mazda::speeD::.
Mazda_Powered
BUMP. i'm open to offers people.
.::Mazda::speeD::.
Mazda_Powered
rx7 turbo fuel pump too!
i've also got a lot of goodies around, check my [FS] threads for any extras!
.::Mazda::speeD::.
