Hey,
Found a topic about cutting the leg of a load sensing circuit on the flasher unit to eliminate the "hyper flashing" after putting in LEDs to replace filiament bulbs.
one q, where is the flasher unit??!!
Quick Q about Flasher Unit
Re: Quick Q about Flasher Unit
The flasher unit is inside the car under the dash (driver side) kinda behind the fuse box - put your flashers on and "hear" or "feel" for the small box that is ticking......
your a star!
thanks for that, ill give it a bash later
