loose Shifting
loose Shifting
I have just bought a 96 MX3 with a 1.8l and its my first.  I have noticed its hard to find the gears.  I have been driving a stick for a long time and this is the one of the hardest.  Is this normal (don''t think so) and how can I correct this problem.  I am looking at a short shifter would that solve the problem or is there bushing that need to be replaced.
						Re: loose Shifting
i wouldnt say loose but the gears are pretty far apart. i got a cheap ebay short shifter for about $20 that help it out tremendously. i got bushings from http://corksport.com/store/category/53f ... train.html
							94 mx3 rs
92 mx3 gs curved neck klze SOLD
- RS_OBD'oh_2
Re: loose Shifting
Wrong forum.
						Re: loose Shifting
Thanks for the info.......Wasn't quite sure were to post
						Re: loose Shifting
Get lots of penatrant.  Go to the dealer and order new bolts front and back and 4 plastic  grommets that go in the linkage.  Install the new bolts and gromments and your shifter will be like new.  I just did mine and it went from sloppy to slicker than snot on a roosters lip.  Be advised, which ever way you go getting the bolts out is tough.  Soak them first then I found using a pneumatic impact chisel the best way to drive the bolts out.
